Oil Pumps
I have a 964 oil pump which is marked: 964.107.130.7R.
I believe that this a magnesium bodied high volume pump with an improved scavenge.
I am considering fitting ot to an early 2.0 magnsium crankcase on a motor we are preparing for a race car but I seem to remember some comments about high levels of expansion causing problems with this pump but can't find the old thread.
I know that the case will need a small mod and we will do the By-Pass modification, I also know that I will need to change the coupling for a short 964 component.
Any other comments welcomed.
Old 07-21-2011, 12:20 AM
964 pump
With all the oil mods you will be fine, we use them as well as the GT3 pumps. just be sure you have a large enough scavenge out system to take full advantage of the larger pump.
Mike Bruns
The two most useless things to a driver are the braking distance behind you and nine-tenths of a second ago.
Old 07-21-2011, 06:13 AM
Try not, Do or Do not
Henry Schmidt's Avatar
The only issue we see with the magnesium 964 pump is a propensity for cracking.
If you choose to reuse a 964, inspect it closely for cracks in the pump body.
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 07-21-2011, 08:54 AM
