Piston Pin contact area damaged??
I just started getting all the pieces of my 964 motor together and just discovered something and I need an experts opinion.
Piston #1 seems to have some corrosive damage. Possible causes are: leaving it in Berryman's Chem dip too long, or from previous owners abuse or previous rebuild. Regardless the pin easily slides through this piston where the same pin on the other pistons which show no damage, need to be pushed with a little force. I can also feel more side movement in the pin with the #1 piston. #1 rod bushing looks clean with no wear. I haven't seen any specs or measurements listed for this area of the piston. Machine shop said everything looked good, but maybe they missed this? Or could it be OK to use as is?
Please advise...
1981 911sc RoW Coupe (forever under 3.6L conversion)
2003 996TT Basalt black
Old 07-30-2011, 10:36 AM
Air Medal or two
afterburn 549's Avatar
See what others think here...good for a bump any way LOL
But - i would consider a bushing for it...if a piston is costly....There are lots of other bushing in a engine....so why not? LOL
i did not say that was the answer,,,I just would table the idea
162 Assault Helicopter Co,(Vultures ) D troop 3/5 Air Cav. ( Bastard CAV) South of Saigon, U Minh Forest, Delta, and most parts in between.
Old 07-30-2011, 03:08 PM
BURN-BROS's Avatar
It looks more like a stain in the pics. Can you feel the damage with your finger?
Have the bore measured my a local machine shop to verify the diameter and any deviation @ that stain. You can use another piston as a reference on size. have them measure a pin while your at it.
Aaron. F.S. 1965 Solex engine w carbs/cleaner
Burnham Performance
https://www.instagram.com/burnhamperformance/
Old 07-30-2011, 03:26 PM
I worked at the spot with some red scotch brite pad before I took the above pictures and it smoothed it out a bit, but I can still definitely feel it with my finger. It feels like it is above the normal piston surface, but if this were the case it would be a tighter fit with the pin... I am afraid if I work at it too much, then there will be way too much clearance between the pin and the piston's orifice. It almost looks like a casting imperfection?
I put the tools down, and everything is on hold until I figure this one out....
Old 07-30-2011, 03:51 PM
abit off center
cgarr's Avatar
Almost looks like damage from someone pounding out the pins at one point?
______________________
Craig
G2Performance
Old 07-30-2011, 04:15 PM
Possibly??? Not by my doing, but maybe done by previous work.
The center section feels raised, but the sides fells like it is into the pistons surface. You can feel it with your finger and when the pin is installed there is a little movement that I can feel that doesn't exist in the other pistons... I will take it by my local Porsche mechanic and see what he says. I have a feeling his answer is going to be: "I wouldn't reuse it."
From what I have shown you in the pictures and explained would you use it or replace it?
If replacing, I am sort of hesitant to try and get another used single or used used set as their condition could be the same or worse...
JE pistons and use my barrels? This really sucks....
Old 07-30-2011, 06:29 PM
Try not, Do or Do not
Henry Schmidt's Avatar
Give me a call. I probably have a replacement for a reasonable price.
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 07-30-2011, 06:35 PM
That would be great. I will give you a call Monday, or sooner if your working this weekend?
M64/01
Tolereance Group: 3 (99.991 - 100.001mm)
Weight Class: - - (644 - 652g)
(You probably know these off the top of your head, but I thought they might help)
Old 07-30-2011, 07:04 PM
Sorry but it will have to be on Tuesday. I'm playing with my airplane on Monday.
Henry Schmidt
Ph: 760-728-3062
Old 07-30-2011, 09:35 PM
