GaryR's Avatar
Send a message via ICQ to GaryR
Head gaskets
Just received my new top end gasket set and the head gaskets I removed seem to be a solid material and the new ones are an open design. Is all ok using them in my 3.0L?
Gary R.
Old 07-30-2011, 10:25 PM
Old head gaskets.........
Gary,
The old aluminum cylinder head gaskets have been compressed and subjected to heat for many years. The new gaskets would look the same as your old ones after some years of usage. I noticed that too and just completed two (2) top & bottom engine rebuilds (SC's) this spring/summer time. You'll be OK.
Tony
Old 07-31-2011, 09:31 AM
GaryR's Avatar
Once I looked at the old ones more closely I could see they were the same, just baked and caked up. Thanks!
Gary R.
Old 07-31-2011, 03:06 PM
Try not, Do or Do not
Henry Schmidt's Avatar
Even if the gasket looks the same, use caution. The new Victor Reinz CE rings are horrible quality. I recently got a Reinz gasket set with an engine from a customer and after building half the engine, disassembled it because I just wasn't happy with these gaskets.
This consistent lack of quality is why we only use Wrightwood Racing gaskets. Charlie is almost fanatical about the quality of the parts he sells.
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 08-01-2011, 05:08 PM
GaryR's Avatar
Originally Posted by liane View Post
I am agree with you boyt911sc.
Gaskets have been compressed and subjected to heat for many years.
toyota cars perth
All good, thanks.
Gary R.
Old 08-02-2011, 04:59 AM
