930 Turbo S engine
I am having my engine rebuilt and the mechanic said its a 930 Turbo S engine which according to him he has not seen many of. they have a had a bit of delay getting parts as some of the parts are from a 935. just seeing if any of you guys know anyhting about this engine and the good bad or anything?
I'm not very familiar with the differences between a 930 and 930S engine but definitely do your research before agreeing to a bill. I can't imagine there are many, if any, 935 specific parts in that motor. There really wasn't much in the way of an increase in HP over the standard 930 if i recall.
For a race motor, the 935 engine was pretty close to a 930 engine, so it all depends on how you look at the parts- the 935 and 936 used a production crankshaft and case, for example.
What is the engine model number? I would look for M30/69S, but I'm not sure.
Pictures would be nice but many of the go-fast parts are probably on the inside. Mark |
its a 930/66 there are quite a few pics of my engine on my thread... had the engine and tranny dropped
I would put a link to the thread if i knew how. its on the 930 turbo page the serial numbers are in some of the pics. |
Which doesn't mean that your car isn't a 930S. If I understand correctly, all of these pre-1987 were Special Wishes cars built in Werk 1, and most were slants (flachbau). There's a good thread covering engine options - and most other aspects of the 930S/930SE models - on the 930 forum http://forums.pelicanparts.com/911-930-turbo-super-charging-forum/447083-slantnose-slant-nose-slope-m505-factory-930s-documents-registry-ultimate-flachbau.html. But I also believed that the 930S came with better cams (SC?), and a K27 instead of the 3DLZ - which would account for the 330HP I seem to recall was quoted for these - an otherwise stock 930 with SC cams should make that. Which isn't to say that Sonderwunschen couldn't/wouldn't build in more power if ordered. Seem to recall reading they built one German customer a 400HP car - which was more powerful than legally permitted for street use at that time... |
yeah it has the k27, not sure on the cams
| All times are GMT -8. The time now is 06:39 PM. |
