Distributor Testing
I have a Bosch Dizzy for a CD box equipped 911 (2.4) that I need to test and would like to measure the advance curve.
I have access to a Marquette Distributor Tester which I have used in the past for checking '001' and '002' distributors without any problem.
Reading the Shop Manual I found the comments below:
I must say that I don't know what is involved in rigging up a suitable system as the marquette doesn't have an 'auxillary coil' setting and as far as I know, neither does a Sun 504.
I would also like to know which box is needed.
Could a 6 pin box be used to test a contact breaker type dizzy normally used with a 3 pin box and a magntically triggered dizzy?
Any comments gratefully received.
Old 08-13-2011, 02:09 AM
Chris,
Most distributor machines trigger very nicely with any kind of point-type units. Magnetically-triggered ones require a pulse amplifier to trigger the machine, however you should be OK.
I have a Sun 504 that does those 2.4 distributors without any issues.
Now, testing the whole system: distributor, CD box & coil on the bench is a totally different situation.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 08-13-2011, 07:42 AM
Steve,
Thanks I only need to test dizzies at the moment but will look into testing the whole system later when I have learnt a bit more.
Old 08-14-2011, 07:35 AM
