break fix drive repeat
rwilner's Avatar
Question on rear axle / hub assembly sequence
I'm going to have my p-car mechanic press in my new trailing arm bushings and wheel bearings on my driver's side trailing arm. I figured, might as well have him press hub into the bearing as well.
Question: what gets bolted to the TA prior to the hub getting pressed in? Is it the entire e-brake assembly and the retaining plate? I want to make sure I show up with all the parts needed.
thx
Rich
Old 11-30-2012, 07:36 AM
rwilner's Avatar
The PET shows only item 13, the retaining plate, behind the hub, but I'm not sure if the ebrake assembly also needs to go on. I would think it does but PET doesn't have an exploded diagram showing it all together.
Old 11-30-2012, 07:49 AM
Trophy's Avatar
You will get more answers in the 911 forum, this is the engine rebuild Forum
Steven
1995 - 993 RS Tribute - 4.0l Engine plus other stuff...
2005 - Touareg V8 Tow Vehicle
Old 11-30-2012, 01:46 PM
rwilner's Avatar
Whoops!
Figured it out anyway. Thx
Old 11-30-2012, 02:30 PM
