No Expert
Is valve guide boss repair on head possible?
Is this head repairable or is it junk? It was this way when I bought it, and discovered this during a tear down.
![]() Thanks, JP --
-- Last Engine rebuild project, Now a coffee table. -- New engine rebuild project, Alive and well. -- '72 911 Martini RS, '69 911E Targa, a 2004 Cayenne S, and a Miata too... Looking for a Cayman S |
abit off center
Anything can be repaired, that looks like it may have been welded at one point. The repair may cost more than a good used head, what motor?
______________________ Craig G2Performance Twinplug, head work, case savers, rockers arms, etc. |
No Expert
It a well used, plain-Jane 2.4 E motor. I was planning to make it a mild 2.5 race motor.
Could not get it done on this one for less than cost of a refurbushed one..
Davy 82 911 SC Targa Sold 12 Audi A5 Sportback 3.0 TDI Quattro 03 996 C4S |
PFM
I think the cylinder is done.....
Stay Tuned, PFM |
^ I'd say so.
This work almost always costs more than a refurbished head for sure. In basic steps I do it by removing the guide, welding up the entire area, setting it up in a mill and boring the guide hole back in, then machining the port boss and testing on a flow bench to get that port back to where it needs to be flow wise. Just alot of labor to do it right. Best of luck!
Adam Hennessy |
The cylinder is done....
And the piston
![]() and the con rod and barrel ![]() and the head ![]() and a lot of internal carnage ![]() moral of the story do not shift from 4th to 3rd at 5,500rpm and 100mph try to hit 5th ![]() all repaired
PFM
Ouch.....
The after shot is much better.
Stay Tuned, PFM |
