Piston Ring Compressor
I am rebuilding an '87 Carrera engine and am wondering what type of piston ring compressor to use. I like the ARP Piston Ring Compressor, P/N 901-9500 but want to make sure I am making the correct decision. Any comments?
Regards, Bill |
I used a Lisle 19000 - 2-1/8" to 5" Take APART Ring Compressor, which is economical and worked pretty good. I also inserted the pistons into the cylinders on the bench before mounting the assemblies onto the case.
Dave |
I like a 1" X 4.25" hose clamp....
bought mine at Sears:)
i can specifically recommend against the $63.00 one Pelican sells (KD850). The bands are painted, so the rings catch on the paint. Also the spot welds where the plier loops attach to the bands are not ground smooth. Once you strip all the paint off and grind the spotwelds down, they work fine.
I got mine at HF and it worked like a champ.
Hazet
Another version of the hose clamp gizmo.......
http://forums.pelicanparts.com/uploa...1465480597.jpg Tony |
I use the kit with bands and pliers, We are pretty lucky having square top cylinders, try putting pistons in a VW VR6 sometime??
Worked great - was super easy to use. Wiseco Ring Compressor Sleeves RCS09500 - Free Shipping on Orders Over $99 at Summit Racing |
http://forums.pelicanparts.com/uploa...1465599278.jpghttp://forums.pelicanparts.com/uploa...1465599381.jpg |
These work very well. My favorite, but we don't have them for all configs. Where we don't have these yet we use the "band with pliers" style which also work well. That said, I am not a fan of installing the piston on the rod (aircooled motors) and then sliding the cylinder over it. Works for some, but not my choice for assembly. Cheers |
regards, al |
| All times are GMT -8. The time now is 12:30 AM. |
