Changing Rod Bolts in sealed case
Hi,
I don't feel 100% comfortable with how I torqued one of the rod bolts in my engine.
Before I slip on the cylinders, I thought I would replace the two on that rod. I have read that I can change the bolts without splitting the case.
Any tips on doing that or is it as simple as unbolting and bolting back to torque as specified? These are the standard rod bolts.
Thanks,
Neil
Neil
'73 911S targa
Old 09-23-2011, 01:37 PM
I've never done this, but my mechanic back in TX has done it quite a few times.. it’s a bit of a bugger to get the sockets on, but i'd go for it if i were you
Old 09-23-2011, 01:46 PM
Stock for stock, why bother?
Bruce
Old 09-23-2011, 05:51 PM
Bruce
I don't feel 100% comfortable with how I torqued one of the rod bolts in my engine. ..
I am not racing, so stock bolts should suffice.
Neil
'73 911S targa
Old 09-23-2011, 06:28 PM
Walt Fricke's Avatar
Neil
Replace your old bolts one at a time. That way the cap and bearings won't be affected. You could just snug up the new ones if you wished, and then when you have both in, torque to the spec you are afraid you messed up on.
I pulled one rod once to check the bearings after an overrev and bent valve(bearings were fine), and was able to get things back together. But no need for the hassle in your case.
Old 09-24-2011, 06:39 PM
I too have replaced rod bearings via the spigots. The con-rod bolts were reused. No issues with frequent 7300 RPM shift points.
Old 09-26-2011, 12:31 PM
Assuming you have access through the opposite cylinder opening, yes. During a rebuild, one can pre-assemble the rods onto the crank or install just the crank, then install the rods through the spigot holes. Works backwards too. Cover all openings with shop towels to prevent those little bits of metal (washers, bolts, bb's, etc.) from being stored inside the engine.
Sherwood
Old 09-27-2011, 01:51 PM
