time certs?
I have asked this question on the tech forum but thought it would be better served here. After removing the intake and shroud i discovered what I beleive to be case savers at hte head studs. Can any one confirm based on just photos. I did touch with a magnet and it did stick apart from the stud. I realize it is hard to say just looking at a photo. A good guess will do
Old 10-17-2011, 01:19 PM
E Sully's Avatar
I would say yes. Neither my 3.2 or 2.4 have any protrusion around the stud base.
Ed
1973.5 T
Old 10-17-2011, 02:37 PM
Thanks Ed. As I have only had 1 other 911 apart it also had no protrusion as you called it, nor did it have timecerts or case-savers.
Old 10-17-2011, 03:47 PM
CaptainCalf's Avatar
they don't look like time-serts to me cuz time-serts are usually flush since they are counter sunk
however, time-serts are magnetic
FS 1987 930 DTAFast EFI w/Electronic Dash, 17x9x11" Lindsey Racing Fuchs, Andial 8.39 R&P, C2 Intake, SuperCup Cams, Flame Ringed Heads & Cylinders, TurboKraft Full Bay Intercooler, RearlyL8 Twin Scroll Headers, Big Bullseye Twin Scroll Turbo...SOLD
1999 Harley Davidson Custom 1250 Hardtail Bobber..SOLD
2014 BMW X6M, 2012 BMW 128i, 2014 GMC Sierra, 2015 Cobia 237 Center Console 300hp Yamaha
Old 10-17-2011, 04:28 PM
83 911 Production Cab #10
JJ 911SC's Avatar
Originally Posted by CaptainCalf View Post
they don't look like time-serts to me cuz time-serts are usually flush since they are counter sunk...
+1, they are counter sunk with a flat top.
Who Will Live... Will See
Old 10-17-2011, 04:44 PM
The engine tin needs to be cut to the bottom, not just to the cylinder.
Well there is some sort of case saver there. If the studs are non magnetic, they are dilivar which is the proper use on a 2.7.
Bruce
Old 10-17-2011, 05:14 PM
Since I have no/little history on this car, the appearance of these make me believe the engine was probably rebuilt during it's life. Not surprising due to the performance and lack of smoke. Also the exhaust has been backdated so the thermal reactors are gone, Once I get the oil to stop leaking onto the floor all will be well. (parts are ordered and "while your in there" has taken over. already gone through a bottle of degreaser and a bunch of rags!
Old 10-17-2011, 07:05 PM
