schematic question
In the Haynes schematic diagrams (which may be copied from factory manuals), a wire may be indicated as 4.0 RD. "RD" ofcourse means red, but what about the "4.0". I used to think it was about amperage, but now I wonder if it is cross section in mm2. Anybody know?
Old 09-24-2011, 10:40 AM
Its the size of the wire.
Bruce
Old 09-24-2011, 11:17 AM
Thanks Bruce. By the way, I've got your motronic mounted on my engine and it's about to go in. Problem is, I've never seen a 3.2 in a 911 and my 911 is a '77. I'm confused about some of the vacuum and other air tubing. Hopefully you can help. I'll try to post some pics later in a separate thread.
Old 09-24-2011, 11:41 AM
You ve got a PM and a phone number.
Bruce
Old 09-24-2011, 02:40 PM
nreed's Avatar
Yes it is mm^2. See the following link for converting back and forth between awg and mm^2
Wire Gauge calculations
Norm '86 930
AEM Infinity 6 - Twin Plug 3.6L - DBW - JE Pistons/LN Eng. Cylinders - Pauter rods - GT3 Crank - GTX3584RS - ID1050x Injectors - Ported Intakes - Custom Intake Manifold, exhaust and intercooler - 993SS cams - ECUMASTER PMU-16DL
HRE Wheels 560R 8.5x18 ET25 (Front) 11x18 ET0 (Rear)
Old 09-24-2011, 07:08 PM
