Intake manifold studs
Removing the CIS system from my 78SC,
4 of the 12 nuts came off with the stud attached. Is this common? Should I reuse the studs? Is it recommended to replace all of the nuts when putting the intake back on the engine? Thanks in advance, |
Use new.. use RED loctite into the block. I put a little antisieze on the outside threads, but many will tell you that this messes up your torque values
Very common with the Exhaust one but 1st time I read about the ones from the Intake.
I use new nuts when I put mine back on. |
Many thanks guys.
| All times are GMT -8. The time now is 11:28 PM. |
