In maintenance phase
Hey Everyone!
I was looking through Wayne's engine book a few nights ago and stumbled on the recommended engines section. He specifies a neat sounding 2.4 essentially built from a 2.2E with a 2.4/2.7 crank. It's buit on 2.2E cams and 2.2E pistons. He says it's about a 10:1 motor that runs well on pump gas and makes a bit more power than a 2.4 because of the higher compression ratio and cams that are a great compromise between high end and drivability. I realized that I have most of the parts just sitting around the garage and started dreaming of putting one of these motors together. However, before I can start any serious thinking about this I need to have a plan... ![]() I need to start with some questions: First: I presently have a 2.2T with E cams and Zeniths. I have been informed by the PO that it may have 2.2E pistons. It definitely has T cylinders. Is there a way to tell what kind of pistons you have while the engine is still being used in a running and driving car? (basically, without tearing it down) I have Carrera tensioners installed now, and they will be used in any build. Second: Should this be using the 2.2 or 2.4/2.7 rods? Third: Are 2.2 and 2.4 cylinders the same? I assume there isn't any serious problem using T cylinders with E pistons? Fourth: Here is the tough one: what is the most cost effective way to do this? I've contemplated getting a 2.4 shortblock, but I'm concerned my distributor wouldn't work (I think the shaft size is different.) Not the end of the world if that's the only problem, but I just rebuilt my distributor and I like it. (it's a 231 159 006 from a 2.2E) I'm afraid to crack a case because I don't want to create an issue with a different crank that may bind with standard size bearings, requiring line boring and (expensive) oversize bearings. I understand the cranks, bearings and cases all sort of wear each other in, and that it isn't as simple as just changing a crank. Goal is to have a reliable motor, still running carbs, used for weekend driving and maybe an extremely rare (less than once a year) DE. No requirement to overbuild, the goal is to build with all used Porsche parts. There will be a new gasket kit, new oil return tubes, new rings, rebuilt 2.2T heads, and the other necessary stuff when digging into a motor. So, if this was your project, and you were planning on using absolute minimum funds and all used parts, what would you do? I'm especially curious about the crank/case issue. Used 2.4 shortblock, or just split a 2.2 and drop in the later crank? All opinions and suggestions are welcome. Thanks! Dan
1969 911T (Getting a 72E heart transplant) 2004 Volvo XC70 Gone, but not forgotten:1971 Bug, 1978 Bus, 1982 Westy, 1996 GTi, 2000 Audi A4 2.8, 2001 Jetta Wolfsburg 1.8T, 2002 Audi allroad 2.7T, 2010 Jetta SportWagen TDi, and a couple of short lived 914s. Last edited by daniel911T; 10-04-2011 at 10:13 AM.. |
Hi Dan,
Came back from a vacation expecting to see news on your transmission project, and here you are starting something else! We seem to have a lot of common projects... This is more or less what I did, with the exception of using JE 9.5:1 pistons instead of original porsche ones. First, my thread, if you haven't seen it: Caterino's 1970 engine rebuild Quote:
So assuming a good shortblock that you didn't have to split, that would seem the better option, although I know most will recommend splitting it anyway, checking the bore, replacing bearings, etc........! But what else do you have to do with all your spare time and money?? Mike
Michael Caterino Clemson, SC 1970 tangerine (=Tiger Orange) 'T' targa restoration: mk911.blogspot.com |
The transmission project is def. still out there, and somewhere near my #1 priority.
This is just a pipe dream at the moment. However, if I know what I need, then taking advantage of future "opportunities" becomes a possibility. ![]() Right now my motor runs great, but I'm already getting a bit of the itch... "how much better could it be if..." It's also fun to imagine doing it on a shoestring, out of someone else's useless parts. One last note: I am not attached in any way to my case. In fact, many of the studs in the case just pull right out when retorqued. I had this trouble on the chainboxes and on a stud that comes out of the bottom of the case near the #1 cylinder. As a further point against this case, according to my research, this is not a case with piston squirters. That was a '71 change, and this is most certianly a '70 case. Thanks for the input! Dan
1969 911T (Getting a 72E heart transplant) 2004 Volvo XC70 Gone, but not forgotten:1971 Bug, 1978 Bus, 1982 Westy, 1996 GTi, 2000 Audi A4 2.8, 2001 Jetta Wolfsburg 1.8T, 2002 Audi allroad 2.7T, 2010 Jetta SportWagen TDi, and a couple of short lived 914s. Last edited by daniel911T; 10-04-2011 at 01:34 PM.. |
