2.0 aluminum case by pass
What is needed to perform a oil bypass mod on the 2.0 aluminum case. I was told the this mod really helps oil pressure at idle. I do find the after my engine is hot the idle oil pressure is really low, but it has great oil pressure off idle when hot and cold.
Old 10-10-2011, 06:50 PM
Try not, Do or Do not
Henry Schmidt's Avatar
If your engine is still together and your only reason to disassemble it is to perform a bypass, try cam feed line restricters. They are great at improving low rpm oil pressure. (that is of course if you don't have center feed cams)
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 10-10-2011, 07:28 PM
The bypass mod does nothing to change your oil pressure. It allows you to use a later oil pump which will increase your oil pressure. It involes drilling a hole to connect two oil passages and pluging an existing hole.
-Andy
Old 10-11-2011, 08:33 AM
