otto in norway's Avatar
QSC cylinders and piston kit revisited
Came across a QSC cylinder and piston kit on ebay. Looks too good to be true/any good. (100mm, 3.5 liter kit for my 3.2)
I see this topic has been discussed here before, but I wonder if maybe things have changed since 2009?
I got to ask, because if they are now of good quality, why go with LN's or Mahles?
Anyone got some experience with this brand since last time??
thanks,
Otto
Old 10-29-2011, 02:17 PM
brads911sc's Avatar
why dont you go with JE's and replated Mahles. Gotta be better than QSC and are reasonably priced.
83 SC Targa -- 3.2SS, GT2-108 Dougherty Cams, 9.5:1 JE Pistons, Supertec Studs, PMO ITB's, MS2 EFI, SSI's, Recurved Dizzy, MSD, Backdated Dansk Sport Stainless 2 in 1 out, Elephant Polybronze, Turbo Tie Rods, Bilstein HD's, Hollow 21-27 TBs, Optima Redtop 34R, Griffiths-ZIMS AC, Seine Shifter, Elephant Racing Oil Cooling.
Old 10-29-2011, 03:21 PM
3.4 Bigger is better
88-diamondblue's Avatar
I have 12,000 miles on my qsc p&c's and it has been great. The comment about it has to be better to bore and replace might be or might not be true. If the QSC kit has been inspected and is good as Supertec does with there kit then you are good to go. Mine from Henry had J&E pistons and the qsc cylinders. No regrets except that I wish I had gone 3.5 instead of the 3.4. A little over 260hp from the rebuild
Michael
88 911 Diamond Blue CE Carrera 3.4 HC3.4 member
2020 Honda Passport
Old 10-29-2011, 07:29 PM
I have nothing bad to say about these, and for all I know they might be fine, but I am pretty sure Henry/Supertec quit using them.
As most of us are often looking to save $$$ when we can, I inquired about these P/Cs for my 3.6 rebuild recently, and he really only said he was no longer using them and would only recommend OEM Mahles.
Old 10-29-2011, 11:05 PM
Thanks...
Looks like things still are as shady as it were before with QSC. That is enough fofr me to not order a set. I can't get any inspected sets anymore, so I feel that I would be gambling too much with that set.
Is it really possible/advisable to bore out my 95mm Mahles to 100mm?
That would be a far cheaper option than buying new sets. Of course, I would need new JE pistons.
Old 10-30-2011, 12:03 AM
(man/dude)
Jonny042's Avatar
If I understand correctly 98mm is the limit on re-bores?
Old 10-30-2011, 07:09 AM
Jeff Alton's Avatar
Correct, 100mm available for cases with the spigot bored and 100mm slip in available through LN Engineering.
Cheers
www.turn3autosport.com
Old 10-30-2011, 08:59 PM
Almost Banned Once
sc_rufctr's Avatar
I just did a quick search on eBay... Woooo. Damn they're cheap.
Anybody know were they are made?
- Peter
Old 10-31-2011, 02:40 AM
Hi guys.
Thanks, for the usual helpful info!
BTW: they are made in china...
Old 10-31-2011, 04:58 AM
