Mystery 911 Camshafts???
I recently fell into a pair of 911 camshafts that I was told came from a 1983 911SC. I have attempted to find the part number in my reference materials (our sponsor's engine rebuilding book and my best internet friend Google), but haven't been able to identify these as a valid camshaft for the 1983 SC.
The camshaft part numbers are:
930.105.148.9R
930.105.147.9R
Would any be able to offer me some advice on how I would go about determining if I can use these for an upgrade to my stock 911SC engine? I am thinking about having them reground to more a more aggressive profile, such as a 964 profile and swapping out my existing pistons with higher compression pistons such as the ones offered by JE. If these are already aggressive (perhaps the R is to designates a "racing" profile?) cam profiles, then I was thinking I might not need to have them reground as much as just sent out to be reconditioned?
Also, does anyone have any experiences, good or bad, with Elgin or Webcam? I am going to send the cams out to have the work done if they can be reused, but cost is a little bit of a factor, which is why I am looking at reconditioning these old cams versus buying new ones for my application. I have a 1982 911SC which has had a total rebuild by a local Porsche mechanic in the last 5,000 miles and am thinking about practical ways to increase the hp a little in my daily driver.
I would really appreciate some input from the expert re-builders on this forum, thank you in advance!
Jeff W.
Old 11-07-2011, 10:29 AM
These are standard SC cams
Tom Butler
1973 RSR Clone
1970 911E
914-6 GT Recreation in Process
Old 11-07-2011, 06:24 PM
I appreciate it, Tom. I also couldn't find my parts in the reference tables I had.
I guess my real question is how do I find out what the cam profile is and whether or not to just recondition it as is or go with a different grind. Since these didn't match up with a "standard" camshaft installed in an '83 SC (or any other model year 911), would one of the camshaft shops be able to give me some input before I make this decision?
I should add that I've never sent anything out to be machined before and wondered which one of the shops might be able to tell me what I have and whether it is a better profile than the one I am considering (a 964 cam profile for my 911SC). Is one of them more "new-owner friendly" than the others?
Thanks again to everyone for their much needed advice on this topic,
Jeff
Old 11-08-2011, 09:22 AM
Jeff
The numbers cast onto the camshaft body are the casting numbers not the finished part number.
The casting numbers you cite look correct for an SC cam
Tom Butler
1973 RSR Clone
1970 911E
Old 11-08-2011, 10:33 AM
