What cams do you recomend
Hi I have a ROW 911 sc with webers, headers, 9.8:1 on 98 octane fuel
Used only for hill climbs, track, Tarmac rally(not a road car)
What camshafts should i be fitting?
Old 05-29-2011, 03:28 AM
You are pretty limited in camshaft choice by the OEM CIS pistons. 964 cams would be a good choice unless you change pistons for more clearance.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 05-29-2011, 10:11 AM
Thanks , Who sells 964 cams and is the improvement worth the cost and effort?
Thanks John
Old 05-30-2011, 05:41 AM
D911SC's Avatar
Hi John,
I'll email you tomorrow with some ideas of where to source the 964's locally.
Darren
My first love - 1993 964 C2 Manual Coupe
My second love - 2021 Macan GTS
Old 05-30-2011, 06:41 AM
j911brick's Avatar
I have some 964 cams for sale. Redone by web-cam on SC cores with only a couple hours run time.
james
www.gruppe9autowerks.com
Its not how fast you go...its how you go fast
Old 05-30-2011, 07:13 AM
Try not, Do or Do not
Henry Schmidt's Avatar
Call John DR Camshafts. He is a frequent contributor here and is willing to help with cam selection.
There are lots of cams that will run with the cis pistons that also work well with Webers. The first cams that come to mind are the webcam 20/21.
Product #05-282 258/246@.050 IN DEGREES: 238/226 485/.452
DR makes a similar cam.
DC 20 Super C2 I/E 248/236 242/230 .470"/.455" 113
Upgrade for Porsche C2 C4 964 or hot 3.2
DC 21 I/E 248/238 242/232 .490"/.470" 112
DC 22 I/E 254/236 247/230 .485"/.455" 113
DC 24 I/E 254/244 247/237 .485"/.460" 113
Dougherty Racing Cams
With all that said, if your thinking about taking you'rr engine apart, you can easily have the pistons cut for vale clearance which lowers the compression slightly but then allows you to use cams with a drastically improved profile. I really like the Mod S cam that DR cams produce. Incredible mid range and more that decent top end.
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 05-30-2011, 07:21 AM
SuperOldSchool's Avatar
Hello all!
Anyone from this discussion still have 964 cams for sale or know where to look?
Jack
1987 Triple Black Cabriolet - Wide Body
2011 Black Cadillac SRX
2007 Black Honda Element SC 5spd (for sale!)
2015 Yukon XL Denali
1966 VW Karmann Ghia
Old 11-16-2011, 07:18 PM
j911brick's Avatar
Originally Posted by SuperOldSchool View Post
Hello all!
Jack
I do.
james
Old 11-16-2011, 09:06 PM
