-   -   Will a 993 SS cam - originally for a 3.2 (http://forums.pelicanparts.com/911-engine-rebuilding-forum/640143-will-993-ss-cam-originally-3-2-a.html)
JeremyD 11-15-2011 07:40 PM
Fit a 964 cam carrier on a 964 3.6? I have the PS pump blocked off. Sure looks like the cam nut is the same.
Flat6pac 11-16-2011 06:36 PM
I dont quite understand the question other than all 3.2, 964, and 993 lock with the same bolt and heavy washer.
Bruce
JeremyD 11-16-2011 07:16 PM
As in - is the cam carrier the same for a 964 as it is for a 3.2 Carrera?
a set of cams were made for a 3.2 carrera - these cams were made with a (993SS grind)
These cams came up for sale with very little hours in good shape by someone I trust.
I would like to know if these will fit a 964 engine that I have...
Flat6pac 11-16-2011 07:43 PM
Yes, they will, all the cam carriers for Carrera and 964 are basically the same, inside, as the cams are the same.
Bruce
JeremyD 11-16-2011 07:59 PM
Thanks Bruce - that's what I thought - but wanted confirmation
KTL 11-17-2011 02:30 PM
Another angle to this is the stock 964 cam is commonly installed/upgraded to Carreras or SCs by grinding off the PS pump drive. So that tells you the 964 cam fits the older cam towers and therefore a Carrera or SC cam will drop into the 3.6 tower.
JeremyD 11-17-2011 02:44 PM
Yeah, I knew that side - was pretty sure - just wanted another opinion...
Jeff Alton 11-17-2011 03:22 PM
Some 89 3.2 motors have cam carriers with 964 part numbers on them as well.
Good luck with your build/repair Jeremy.
Cheers
JeremyD 11-17-2011 03:44 PM
Thanks Jeff.
