MBruns for President
Will a 993 SS cam - originally for a 3.2
Fit a 964 cam carrier on a 964 3.6? I have the PS pump blocked off. Sure looks like the cam nut is the same.
Current Whip: - 2003 996 Twin Turbo - 39K miles - Lapis Blue/Grey Past: 1974 IROC (3.6) , 1987 Cabriolet (3.4) , 1990 C2 Targa, 1989 S2 |
I dont quite understand the question other than all 3.2, 964, and 993 lock with the same bolt and heavy washer.
Bruce |
As in - is the cam carrier the same for a 964 as it is for a 3.2 Carrera?
a set of cams were made for a 3.2 carrera - these cams were made with a (993SS grind) These cams came up for sale with very little hours in good shape by someone I trust. I would like to know if these will fit a 964 engine that I have...
Yes, they will, all the cam carriers for Carrera and 964 are basically the same, inside, as the cams are the same.
Bruce |
Thanks Bruce - that's what I thought - but wanted confirmation
Schleprock
Another angle to this is the stock 964 cam is commonly installed/upgraded to Carreras or SCs by grinding off the PS pump drive. So that tells you the 964 cam fits the older cam towers and therefore a Carrera or SC cam will drop into the 3.6 tower.
Kevin L '86 Carrera "Larry" |
Yeah, I knew that side - was pretty sure - just wanted another opinion...
Some 89 3.2 motors have cam carriers with 964 part numbers on them as well.
Good luck with your build/repair Jeremy. Cheers
Turn3 Autosport- Full Service and Race Prep www.turn3autosport.com 997 S 4.0, Cayman S 3.8, Cayenne Turbo, Macan Turbo, 69 911, Mini R53 JCW , RADICAL SR3 |
Thanks Jeff.
