I once ran washer shaped sensors under the spark plugs on a turbo 914, but had difficulty securing the washers reliably. I believe Elephant sells an oil temp probe that is inserted in the fins of the cooler to switch a relay on to the fan. chris |
Looks like tightening the sensor clamps it all in place - clever.
Might not be good for the sensor tho?
I'm wondering if there is enough meat in the head, to bore the 10mm hole, and thread it, so the sensor can go straight into the head itself... |
Walt, I agree... Seems very ingenious.
Mike, can you expand on your concern? I see a concern with pressure on the tip if the area below the threads is insulated and not one piece with the threaded area. I would think the direct contact is a good thing if one piece? I suspect the sensor reading would be more accurate with direct contact with the head. I do wonder if that specific sensor pulls the temp from the end/tip or an average of the whole sensor below the hex. |
Yes, good idea. Many bolt knock sensor bridges to the bottom of the heads successfully so there is no reason not to drill and tap for a temp sensor. https://i.imgur.com/vGQGl8N.jpg |
| All times are GMT -8. The time now is 07:04 PM. |
