Idler arm and sprocket bushings
I need to have the bushings for my idler arms (late wide base) and sprocket replaced and cannot find a part number. Our host does not have them. Does anyone have a source? Can any good machine shop supply and install them? Any recommendations in DC Maryland area? Engine w is 2.7 RS mfi. Thanks, Al
Old 11-29-2011, 05:26 PM
KTL KTL is online now
Schleprock
KTL's Avatar
The idler arm sprocket wheel is part number 901.105.055.00
The bushing is not spec'd as a replacement part as far as I know. But yes, a good machine shop can source a suitable bushing, press it in, ream to size and you're good to go.
cgarr here on the forums has a solution to the idler bushings. He's located in Michigan. Get in touch with him and he'll set you up with a very nice installation. Nice guy who knows his way around machining equipment.
Kevin L
'86 Carrera "Larry"
Old 11-30-2011, 06:58 AM
Thank you. I will contact him. Al
Old 11-30-2011, 03:37 PM
burgermeister's Avatar
This worked for me (sprockets and idler arm):
idler arm bushing replacement
'88 Coupe Lagoon Green
"D'ouh!" "Marge - it takes two to lie. One to lie, and one to listen"
"We must not allow a Mineshaft Gap!"
Old 12-06-2011, 05:10 PM
