txhokie4life's Avatar
Dodged a bullet
Well actually a nut.
In may of last year I picked up my RSR. It came as a chassis and
a half dozen or more Rubbermaid boxes.
I disassembled what was left of the original engine and decided it would be quicker
and easier to just start with a street engine. Picked up a 1990, 3.6
that needed a serious valve stem replacement and top end work.
I spent the summer performing my first ever solo engine rebuild. (at least the top 1/2).
I also had to debug and resurrect/retrofit the RSR Motec system.
Packed it into my Toter and had it tuned up locally -- Pulled 251hp to the wheels. :-)
On my first track event after having rebuilt and restored my RSR replica, and driven
it for the first time ever, I awoke the second day to a loud knocking
noise in the engine, drivers side -- seemed to be #3.
I hadn't heard it inside the car the day before -- but as that was my first
time on the track with the car -- and it's loud as crap in general, hard to say from
within the cockpit if it was already making noise at end of day or not. Lesson one,
listen to the car after a good track day from inside and out!
Got home and started the diagnosis.
I had pretty good compression ratios across the board.
175, 210, 180, 190, 200, 200.
all leakdown < 8%.
Not bad for a 120K mile engine that I just did the top end on.
Nothing in the oil filter. Hmm, maybe I did a mis-shift and busted a rocker arm.
Pulled the valve covers. Found #1 intake a little out of spec from an adjustment
point of view. but nothing that would indicate this level of noise.
Then we pulled the lower valve cover.
Wow -- #1 exhaust valve adjust nut had backed out -- and clearly the rocker
had been free to bang away
Found the nut, holy cow --
I always say life is about tuition, you just hope you don't pay too much.
The engine gods must have been happy with my efforts that day
as they gave me a huge hall pass.
We inspected the rocker, the cams, and anything else we could see.
Not a scratch or scuff anywhere. The rocker knocking appears
to have been just audible and the nut found the safest place
in the engine in a hurry!
Obviously I don't remember NOT tightening down that nut on the set screw,
but clearly blames on me.
Look forward to redoing the valve adjustments, -- triple checking the nuts -- buttoning
things back up -- firing her up (and rechecking the compression) and
getting back out to the track!
a very humbled and happy RSR owner,
Mike
2015 Panamera Hybrid, 2008 Cayenne Twin Turbo
2001 996 GT2
1999 Spec Boxster, 1996 993 Cabriolet
1992 964 Cabirolet, 1975 911 RSR Replica Race Car
Old 01-18-2012, 10:57 AM
Wow you certainly did dodge a bullet.
Gone
92 C2
82 Euro SC race car
993 C4S 3.8
84 Euro Carrera
Old 01-18-2012, 11:20 AM
Mike, We'll call you..."Lucky".
Scott - 1987 930: 3.45L Supertec engine w/GT3 crank, California Motor Sports upgraded 930 trans, modified suspension, Zuffenhaus 9's and 11's, black on black..."The Black (Financial) Hole"
Old 01-18-2012, 12:14 PM
What an incredible picture! I hope you bought a lotto ticket that day.
1987 GP White 930
1977 Ford Bronco
Old 01-18-2012, 12:33 PM
well done in spotting it.
I have been fond of a little dab of paint on lock nuts etc to be sure that I have tightened them.
That iconic profile of the rear end looks great by the way!
Old 01-18-2012, 01:37 PM
Wow.
Old 01-18-2012, 04:49 PM
KTL KTL is offline
Schleprock
KTL's Avatar
That's the reason right there I want my sump plate (3.0L case) to have a drain plug with a magnet on it. Congrats on the luck!
BTW what size are your wheels. Just curious what sizes the Goodyears are.
Kevin L
'86 Carrera "Larry"
Old 01-19-2012, 08:34 AM
Glad it was the exhaust rocker as gravity works.
Had it been an intake rocker -- it might have found its way into the chamber.
10.5" fronts, 13" Rears. 16" rims.
After these tires go I'll be moving to 12" as the Indy series runs them and you can get scrubs
for a reasonable price. Have a set at the shop waiting to be mounted.
Mike
2001 996 GT2
Old 01-19-2012, 11:46 AM
356RS's Avatar
Great story Mike and thanks for sharing.
Mark Jung
Bend, OR
MFI Werks.com
Old 01-19-2012, 12:01 PM
Well I believe you have to share the good with the bad --- and since this appears
to have a happy ending -- with only my pride taking the fall --
I'm ok with that!
m
2001 996 GT2
Old 01-20-2012, 06:04 AM
