Spring snaked its way up the pickup and was digested by the pump, with similar results. Amazingly the engine ran for another 30k miles until it died one of the more common M96 deaths. |
Alright, just ordered a new set of 964 cams from WebCam which were in stock and ready for immediate shipment. Any idea of who would be able to recondition my rocker arms in a timely fashion?
unrelated,but caught the rock climbing bit. Having the same problem.My 50 yo body having a hella time keeping up with my 16 yo son on the multipitch routes.got him turning wrenches on my 2.2 rebuild.Nice to be leading again,so to speak,hehe.
Chris |
Well, got everything reassembled and the engine started first try. Unfortunately, idle was too high and after a thorough search for the usual 3.2L manifold/TB leaks, a pressure test revealed leaking the of the intake manifold to head interface of #5. Off came the intercooler and this is the unfortunate finding.
http://forums.pelicanparts.com/uploa...1343005026.jpg http://forums.pelicanparts.com/uploa...1343005045.jpg The nut obviously wouldn't hold a torque when checked before this disassembly. No sign of any problem prior to reassembly. |
That appears to have been broken for some time. A fresh break leaves a crystalline surface but those have clearly been rubbing against each other. You can often determine where a crack started in a failed component as the early portion will look burnished while there will be fresh crystalline metal in the area that finally snaps. In this case I'd guess that the lug broke during assembly and has been fretting since then.
Regards, Phil |
A competent welder ought to be able to fix that for you easily enough. A little work with a die grinder to smooth where he welded inside, and good to go.
Would be good to try to figure out how it came to break, though. Something had to be out of whack for torque on the nut on the stud to break that off. Bad gasket or thermal isolator? Hard to imagine that the head surface is not true, or, for that matter, that the manifold surface was out of true either. Both machined surfaces. Not something really nasty, like a leak in the cylinder to head interface, as you started out deciding on how to avoid. |
I'll see if I can get it welded. I don't think I want to try it with my minimal MIG skills. |
I don't think you can MIG aluminum. There are spool guns for aluminum wire which I believe can be used with a MIG machine for this, but they are expensive. Expensive enough that a guy might be better off saving his pennies for a TIG.
Based on my one time use of a friend's TIG, I wouldn't attempt it myself - much trickier than MIG for those of us who are self taught. Not hard for those who know what they are doing, though. I bet you are designing a different support system for your intercooler as we speak. |
I actually have a spool gun for my MIG but very little experience using it so I'll get it TIG'd professionally. I had already modified the mount when the support bracket for the IC cracked using a rubber isolator but I guess it was too little too late. The engine is now very well balanced so I think that will significantly decrease stress on the manifold.
Initial break in is accomplished. Took the car out on the hill and did a lot of runs up to 5K and then close throttle decels to seat the rings then did some general VE tuning around town. I was worried about off idle and around town acceleration with the drop in CR from 10.5 to 8.5 but really did not notice anything (did step up displacement to 3.4 from 3.2). It was really hard to keep the car out of significant boost, that GT35R really spins up fast.
Another big improvement is the Rebel Racing rear torsion bar bushings. My rubber replacement ones squeaked too much, these are rock solid and super quiet. |
Update!!! Hows it running?
| All times are GMT -8. The time now is 05:30 AM. |
