Cleaning Clutch Parts
Can I use brake cleaner to clean up all the clutch dust on my clutch disk and pressure plate? If not, what would you suggest.
Ernie 98 993 C2S - Arena Red/Beige 76 914/6 3.2 Conversion - Estorill Blue/Coral Red Last edited by earossi; 01-12-2012 at 04:08 AM.. |
I wouldnt put it on the disc, Why do you need a clean disc?
Bruce |
I was thinking in terms of cleaning all clutch parts before reinstalling. I would rather put clean parts back into the car. I could just use air to clean up the disc if chemicals are not wise.
Schleprock
A good degreaser like simple green and soapy water rinse works fine on the clutch and flywheel. DON'T blow it with your air hose. You'll blow a bunch of clutch dust & rust into the air and then breathe it.
Kevin L '86 Carrera "Larry" |
