Early 3 pin CDI /82V Zener Diode
Hi Forum.
suprise suprise. I was changing the Zener Diode on an early 3 pin CDI and had a new diode 1n3003B in my hand. So I found out that there are Zener with Std Anode polarity to case stud and reverse polarity of cathode to case stud. See pictures on early type. http://forums.pelicanparts.com/uploa...1326911569.jpg Here the 82V case stud hangs on the collector of the 2n3055 transistor and here later http://forums.pelicanparts.com/uploa...1326911656.jpg the case stud of the Zenner is paraelle to the Emitter of the 2N3055. Tricky thing watch out. saves you time BR Bob |
| All times are GMT -8. The time now is 11:51 AM. |
