HKZ Bob's Avatar
Early 3 pin CDI /82V Zener Diode
Hi Forum.
suprise suprise. I was changing the Zener Diode on an early 3 pin CDI and had a new diode 1n3003B in my hand.
So I found out that there are Zener with Std Anode polarity to case stud
and reverse polarity of cathode to case stud.
See pictures on early type.
Here the 82V case stud hangs on the collector of the 2n3055 transistor
and here later
the case stud of the Zenner is paraelle to the Emitter of the 2N3055.
Tricky thing watch out. saves you time
BR
Bob
Old 01-18-2012, 10:36 AM
