Race Engine pieces
I am looking to duplicate what we have on a 2.9 on our 3.6. We need a thermostat block plate, looks just like the thermostat on the top of the case, but it is just a blank plate, 901 number on it.
We are also looking for a cooler block off, sort of like the Patrick version, just no filter provisions. looks like a custom fabbed original cooler, with a -16 bung welded. Do any of the builders know where to source these items?SmileWavy TIA |
I can't help you with the parts, but what I did to bypass my cooler was this: Remove the "guts" of a stock thermostat and put two blocking discs in the oil cooler holes to block the flow. The discs were turned on a lathe, but 2 pennies also fit fine. The regular seals still work with the discs in place. Removing the guts of the thermostat is easy. The steel end on the bottom just pops off and the spring and cylinder pull out. Then you can block the air through the cooler with a sheet of aluminum.
-Andy |
Check out my old ad
http://forums.pelicanparts.com/porsche-911-used-parts-sale-wanted/608646-remote-oil-filter-kit.html You could put pipe plugs in wher the AN fittings are. I also have the thermostat block off. I will sell you the console, no filter or plumbing and the blockoff for $200 |
Do you have pictures of all installed?
No I don't. I never ran it. Ended up with a 993 filter and Woods adaptor for the -16.
200 shipped to 19342 in PA and its a deal...
Also, post a pic of the blockoff plate.. Let me know.. Andrew |
I found some plugs for the lines and will include them. My Paypal addess is
neil.cawley@comcast.net I accept your terms Here ae the pictues of what you would get http://forums.pelicanparts.com/uploa...1329090335.jpg Use the normal Porsche O rings to mount http://forums.pelicanparts.com/uploa...1329090399.jpg |
you got CASH!!!
Thanks! Andrew |
Got it,
I have to get to the post office! |
| All times are GMT -8. The time now is 04:05 PM. |
