ONQRACIng's Avatar
Thumbs up Race Engine pieces
I am looking to duplicate what we have on a 2.9 on our 3.6. We need a thermostat block plate, looks just like the thermostat on the top of the case, but it is just a blank plate, 901 number on it.
We are also looking for a cooler block off, sort of like the Patrick version, just no filter provisions. looks like a custom fabbed original cooler, with a -16 bung welded.
Do any of the builders know where to source these items?
TIA
Old 01-21-2012, 10:48 AM
I can't help you with the parts, but what I did to bypass my cooler was this: Remove the "guts" of a stock thermostat and put two blocking discs in the oil cooler holes to block the flow. The discs were turned on a lathe, but 2 pennies also fit fine. The regular seals still work with the discs in place. Removing the guts of the thermostat is easy. The steel end on the bottom just pops off and the spring and cylinder pull out. Then you can block the air through the cooler with a sheet of aluminum.
-Andy
Old 01-21-2012, 11:00 AM
neilca's Avatar
Check out my old ad
Remote oil filter kit
You could put pipe plugs in wher the AN fittings are.
I also have the thermostat block off. I will sell you the console, no filter or plumbing and the blockoff for $200
Old 01-21-2012, 01:18 PM
ONQRACIng's Avatar
Do you have pictures of all installed?
Old 02-02-2012, 12:32 PM
neilca's Avatar
No I don't. I never ran it. Ended up with a 993 filter and Woods adaptor for the -16.
Old 02-06-2012, 02:01 PM
ONQRACIng's Avatar
200 shipped to 19342 in PA and its a deal...
Also, post a pic of the blockoff plate..
Let me know..
Andrew
Old 02-12-2012, 11:05 AM
neilca's Avatar
I found some plugs for the lines and will include them. My Paypal addess is
neil.cawley@comcast.net
I accept your terms
Here ae the pictues of what you would get
Use the normal Porsche O rings to mount
Old 02-12-2012, 03:48 PM
ONQRACIng's Avatar
you got CASH!!!
Thanks!
Andrew
Old 02-12-2012, 04:03 PM
neilca's Avatar
Got it,
I have to get to the post office!
Old 02-12-2012, 05:27 PM
