stevepaa's Avatar
964 valve adjust
I don't know why, but when I started to check my valves to do a valve adjust again, cyl 1 was at .125 mm not .1 mm and it looks like I was using a .15 mm shim for this last time.
correct me if I am wrong, but no matter what grind elgin did to my cam, I should still set the valves to .1 mm.
correct?
steve
old rocket inguneer
Old 02-12-2012, 10:31 AM
The cam doesnt change the spec for the engine. The spec is a measuerment on the back side of the lobe and you rock to .1mm.
Bruce
Old 02-12-2012, 11:27 AM
stevepaa's Avatar
thanks, I thought so, but my mind slips in old age.
steve
old rocket inguneer
Old 02-12-2012, 11:45 AM
