Floods on startup
Hey guys, been trying to get my new build CIS 3.4 going for a couple of days. Have spark and gas, but can only get a couple of backfires for ignition. Timing should be close. Problem is it floods within a couple of secs of cranking. Any thoughts would be appreciated. Philip
180*
So I cant get it running as is. Must be out by 180*. If #1 is TDC should # 6 exhaust valve be open? Got the headers off now, and if someone could confirm TDC by this, I would be happier putting it back together. Philip
turned it 180*
and it started right up. Philip
... and you said you were no good at electrical stuff...
Now let get her tune-up so that you could be in front of me for a change :D:):D |
| All times are GMT -8. The time now is 11:09 AM. |
