Floods on startup
Hey guys, been trying to get my new build CIS 3.4 going for a couple of days. Have spark and gas, but can only get a couple of backfires for ignition. Timing should be close. Problem is it floods within a couple of secs of cranking. Any thoughts would be appreciated. Philip
87 930 GHL/Rarlyl8/Garretson/GT3582R/1 Bar/Wevo shift, mounts/Meth inj/LM-2/Custom Fuchs/Carrera intake manifold/Xtreme Carrera heads P&P/3.4/DR 993SS cams/ Mahl/Pauter/JE/Niresist/ARP/twin COP/8.25:1/KEP stage 2/twin tials/close 2,3,4th. MS3Pro Evo 500+ HP, BTSOMP Dyno
180*
So I cant get it running as is. Must be out by 180*. If #1 is TDC should # 6 exhaust valve be open? Got the headers off now, and if someone could confirm TDC by this, I would be happier putting it back together. Philip
turned it 180*
and it started right up. Philip
83 911 Production Cab #10
... and you said you were no good at electrical stuff...
Now let get her tune-up so that you could be in front of me for a change ![]() ![]()
Who Will Live... Will See ![]() ![]() ![]() 83 911 Production Cab #10, Slightly Modified: Unslanted, 3.2, PMO EFI, TECgt, CE 911 CAM Sync / Pulley / Wires, SSI, Dansk Sport 2/2, 17" Euromeister, CKO GT3 Seats, Going SOK Super Charger |
