9191 doesn't fit
The pins on my cam sprocket holder tool don't exactly align with the holes in the sprocket. Has anyone had any luck grinding off material with a dremel?
I saw that a couple guys posting to this thread took their tools to machinists. Wondering if that's necessary.
964 Cams: metal shavings found
1983 SC
Blog
Old 02-20-2012, 05:09 PM
KTL KTL is online now
Schleprock
KTL's Avatar
Baby,
I can assure you cstreit didn't take his 9191 cam tool to a machinist. He certainly hand-shaped it with a file or bench grinder to make the pins fit more cleanly in the sprocket holes
Kevin L
'86 Carrera "Larry"
Old 02-21-2012, 08:55 AM
Thanks, Kevin! That's all I needed to hear.
1983 SC
Blog
Old 02-21-2012, 09:38 AM
