-   -   Dropping 83 911sc motor, stuck on a fuel line... (http://forums.pelicanparts.com/911-engine-rebuilding-forum/660927-dropping-83-911sc-motor-stuck-fuel-line.html)
graups 02-25-2012 07:57 PM
Hello, I'm dropping the motor out of my 83 sc which was going pretty smoothly but I can't seem to figure out this fuel line connector.
On one side is a 17mm nut that appears to be fused to the aluminum fuel line. On the other is what looks like a screwed in termination with two flat sides. The sides don't really match well with any metric or standard combination wrench I have. I can used a thin crescent wrench on it but it is not a good fit, almost as if the flats are not quite flat. I have applied force to it this way but was not able to get it to break free. I didn't push it too hard since the wrench does not feel like it is seated too well.
Besides a couple of minor electrical connections I believe this and the transmission is all that's left to drop the motor. (I've been using the 101 projects book as a guide).
I have attached a picture of the fuel line with a circle around the odd connection. Any clues are greatly appreciated.
scott.
http://forums.pelicanparts.com/uploa...1330228511.jpg
Flat6pac 02-26-2012 05:13 AM
Break the line closest to the engine.
Bruce
graups 02-26-2012 04:49 PM
Bruce
Is there a special sized wrench that fits better on the weird hose side of the fitting or should I just make due with an crescent wrench?
Thanks,
scott.
Flat6pac 02-26-2012 07:00 PM
One side is a 17mm and the small flat is 12mm, but that small side is loose so it could be an 11 before there was 30 years of installings.
Bruce
http://forums.pelicanparts.com/uploa...1330311608.jpg
http://forums.pelicanparts.com/uploa...1330311620.jpg
jrolstin 02-27-2012 01:27 AM
+1 I just did this a few weeks ago and I thought to myself "this can't be oem..." but yours is just as twisted as mine was! :P
BoxsterGT 02-27-2012 06:38 AM
I don't think that hose is available new from Porsche any longer, but you can replace it with one that I make from standard Metric fittings. No problem getting a flare nut wrench on these.
Heres a similar one that I make...........
http://forums.pelicanparts.com/uploa...1330353180.jpg
to replace the hose at the fuel accumulator on 911SC's that I know is NLA. Of course your hose would have a straight instead of the 90 fitting shown. These are made to order, so any configuration is possible.
Len at Autosportengineering dot com
1982911SCTarga 02-29-2012 01:47 PM
Scott, that fitting is the worst of the bunch. Here's my adventure with it. Good luck!
Brian
burgermeister 02-29-2012 02:32 PM
You can always cut the hose and deal with the fittings once the engine is out. All the rubber fuel line bits ought to be replaced anyway. On my 1988, I was really shocked at all the cracks in the fuel lines ...
You can just get FI hose from FLAPS (you need 2 sizes - the SAE stuff in 5/16 & 3/8 (I think) will work, metric is a better fit but harder to find), along with FI hose clamps (or oetiker clamps) and replace the rubber bits yourself - I assume the SC is similar to the motronic in that regard. Or get your lines "remanufactured" with crimps - just make sure they're factory style crimps, not straight hydraulic hose crimps.
BoxsterGT 02-29-2012 04:37 PM
If you just want fittings or hose, I have the right stuff.
Everything is sent US Postal Priority Mail w delivery confirmation. 2-3 days coast to coast.
Len
Flat6pac 02-29-2012 06:22 PM
The factory design had the twist. It is the return line on the system and if the 78/79 twisted it could cause the pressure to go out of control.
Bruce
vinny c 03-04-2012 09:12 AM
I could not break either end loose when dropping engine and ended up cutting it.
Our host sells this hose:
911-356-089-01-OEM
Vince
