Dropping 83 911sc motor, stuck on a fuel line...
Hello, I'm dropping the motor out of my 83 sc which was going pretty smoothly but I can't seem to figure out this fuel line connector.
On one side is a 17mm nut that appears to be fused to the aluminum fuel line. On the other is what looks like a screwed in termination with two flat sides. The sides don't really match well with any metric or standard combination wrench I have. I can used a thin crescent wrench on it but it is not a good fit, almost as if the flats are not quite flat. I have applied force to it this way but was not able to get it to break free. I didn't push it too hard since the wrench does not feel like it is seated too well. Besides a couple of minor electrical connections I believe this and the transmission is all that's left to drop the motor. (I've been using the 101 projects book as a guide). I have attached a picture of the fuel line with a circle around the odd connection. Any clues are greatly appreciated. scott.
Break the line closest to the engine.
Bruce |
One side is a 17mm and the small flat is 12mm, but that small side is loose so it could be an 11 before there was 30 years of installings.
Bruce ![]()
Enthusiast
+1 I just did this a few weeks ago and I thought to myself "this can't be oem..." but yours is just as twisted as mine was! :P
Jonathon 1982 911 SC www.avrmotorsports.com |
![]() I don't think that hose is available new from Porsche any longer, but you can replace it with one that I make from standard Metric fittings. No problem getting a flare nut wrench on these. Heres a similar one that I make........... ![]() to replace the hose at the fuel accumulator on 911SC's that I know is NLA. Of course your hose would have a straight instead of the 90 fitting shown. These are made to order, so any configuration is possible. Len at Autosportengineering dot com
'82 SC Targa '83 SC Cabriolet |
You can always cut the hose and deal with the fittings once the engine is out. All the rubber fuel line bits ought to be replaced anyway. On my 1988, I was really shocked at all the cracks in the fuel lines ...
You can just get FI hose from FLAPS (you need 2 sizes - the SAE stuff in 5/16 & 3/8 (I think) will work, metric is a better fit but harder to find), along with FI hose clamps (or oetiker clamps) and replace the rubber bits yourself - I assume the SC is similar to the motronic in that regard. Or get your lines "remanufactured" with crimps - just make sure they're factory style crimps, not straight hydraulic hose crimps.
'88 Coupe Lagoon Green "D'ouh!" "Marge - it takes two to lie. One to lie, and one to listen" "We must not allow a Mineshaft Gap!" |
![]() If you just want fittings or hose, I have the right stuff. Everything is sent US Postal Priority Mail w delivery confirmation. 2-3 days coast to coast. Len
The factory design had the twist. It is the return line on the system and if the 78/79 twisted it could cause the pressure to go out of control.
Bruce |
I could not break either end loose when dropping engine and ended up cutting it.
Our host sells this hose: 911-356-089-01-OEM Vince |
