Oil Cooler - Leak
I have installed a New Oil cooler on my 2.4 not too many miles ago and I am beginning to see another leak. Although, i dont believe its the cooler itself, but instead I believe it to be the Seals to the engine. This appears to be the same spot in the past.
Any ideas on what to check/ any tricks to ensure the round seals are being compressed enough to the block and cooler?
71 Targa 2.4 WEBERS 915 box Drivetrain - http://forums.pelicanparts.com/porsche-911-technical-forum/410787-drivetrain-project-complete-3yrs-pics.html Interior - http://forums.pelicanparts.com/porsche-911-technical-forum/452686-interior-refurb-carbon-fiber-71-a.html#post4433500 |
Are you sure the leak isn't coming from above the cooler and leaking down?
Did you use the green O-ring seals? Torquing the cooler mounting nuts will assure a good seal.
Pete 79 911SC RoW "Tornadoes come out of frikkin nowhere. One minute everything is all sunshine and puppies the next thing you know you've got flying cows".- Stomachmonkey |
Im wondering if it could be that the metal(block) to metal(cooler) isnt a tight enough gap.. thus not allowing for the gaskets to compress enough?
71 Targa 2.4 WEBERS 915 box Drivetrain - http://forums.pelicanparts.com/showthread.php?t=410787 Interior - http://forums.pelicanparts.com/showthread.php?p=4433500#post4433500 |
I've had 3 coolers fail in the last 5 years. I haven't seen the seals ever leak. There can be a leak behind the cooler where the steel insert shows through for one of the oil galleys. Most people put JB weld on the area.
-Andy
72 Carrera RS replica, Spec 911 racer |
Now that sounds like an area for me to check. Do you have a pic of that spot to JB?
I came across this post.
Case & JB Weld question Is that the area you are referring to JB WELD? ... Should the cap nuts also have Black sealant applied to the threads as added precaution?
