Is this case repairable?
Hi
I have a 2.7 case that has the side of the main bearing retainer broke off (see picture). Does anyone know if there is a repair for this? Also I was wondering how to find out if the case I have is the original one from the car. I know it is the right year of case for the car but that is as far as I can figure out.
Air Medal or two
Yes
D troop 3/5 Air Cav,( Bastard CAV) and 162 Assult Helicopter Co- (Vultures) South of Saigon, U Minh Forest, Delta, and all parts in between |
Yes is a good answer.
Now maybe a little more detail on the how? I have some thoughts but assume there might be a more know standard repair out there. Thanks |
I would rather be driving
I see you have the mid-7R case that has bearing tang recess on both sides of the case. A simple solution would be to buy the set of bearings that locate on the opposite side of the case.
These do exist but I do not know a part number for them.
Jamie - I can explain it to you. But I can not understand it for you. 71 911T SWT - Sun and Fun Mobile 72 911T project car. "Minne" - A tangy version of tangerine #projectminne classicautowerks.com - EFI conversion parts and suspension setups. IG Classicautowerks |
Air Medal or two
Most any "Good"repair shop will have the know how or have a source for a outside vendor to weld that.
Both Mag cases and Al. can be welded and then machined. It always comes to the point.......how much is it worth to the amount you want to spend.. Clewitt had my Mag case welded somewhere.......He is not the only answer..just one
Send it to Ollies in Lake Havasu.
'66 911 #304065 Irischgruen ‘96 993 Carrera 2 Polarsilber '81 R65 Ex-'71 911 PCA C-Stock Club Racer #806 (Sold 5/15/13) Ex-'88 Carrera (Sold 3/29/02) Ex-'91 Carrera 2 Cabriolet (Sold 8/20/04) Ex-'89 944 Turbo S (Sold 8/21/20) |
Air Medal or two
Have all the updates don on your 2.7 while there
Banned
yes Ollies will be one of the few choices to fix it
They fix fixed this for me
This case is in need of most of the updates and a repair. That is why it would be good to know if it is the original engine out of the car. If it is not the original engine from the car it might be easyer to find a case that is good and already to be assembled.
Try not, Do or Do not
If the only problem with the case is that the tang retaining groove has lost the small piece you could very easily put a new groove in the opposite web.
You still want to have the line bore checked by a professional (Walt @ Competition Engineering or Bill @ Engine Machine Service) but the tang groove is an easy repair.
Henry Schmidt SUPERTEC PERFORMANCE Ph: 760-728-3062 Email: supertec1@earthlink.net |
Air Medal or two
If you do find one all together.....its a shot in the dark with out proof IF all the up dates are in fact if there or not.
Paper work trail I do guess.........
Get the Certificate of Authenticity from Porsche. It's over a hundred bucks but if you are concerned about numbers matching, you need it. (they are not always accurate either, particulalry when it comes to options, but the engine and trans numbers should be ok)
My Certificate of Authenticity came back with a number way off from my engine when requested (in 2003?) I contacted Porsche and let them know I thought it was in error (but gave them the number as ######XX to make sure they didn't just agree with me. They came up with the right number. Thank God!
75 911S Targa - Mine from 2001 until sold to Germany buyer 10/2016 <ALL DIY> Brakes/Wheels '01, Body/paint/restoration 7/04, Suspension 3/07 Engine rebuild - done 7/08 - added 28 tube cooler and SSIs - running strong. Ducktail painted. 2021 MachE, 2012 Outback, 2019 Crosstrek, 2018 Impreza wagon |
