-   -   Looking for ideas on how to paint my engine (http://forums.pelicanparts.com/911-engine-rebuilding-forum/664421-looking-ideas-how-paint-my-engine.html)
Juggino 03-09-2012 07:20 PM
I have my 3.0 dropped doing a top end rebuild and headstuds. Just cleaned up and sandblasted most of the parts. Anyone have any photos I could get ideas from on how to paint the fan, shroud, etc????
Henry Schmidt 03-10-2012 11:05 AM
Black fan ring, silver fan (both powder coat) and amber shroud
http://forums.pelicanparts.com/uploa...1331405523.jpg
Gibbs fan and ring with amber shroud
http://forums.pelicanparts.com/uploa...1331405610.jpg
Gibbs fan and ring with yellow shroud
http://forums.pelicanparts.com/uploa...1331405659.jpg
Black and red ring and fan with red shroud
http://forums.pelicanparts.com/uploa...1331405704.jpg
Gibbs fan and ring with red shroud
http://forums.pelicanparts.com/uploa...1331405746.jpg
Bare metal (aluminum) fan and ring with amber shroud
http://forums.pelicanparts.com/uploa...1331405827.jpg
Powder coated silver ring and fan with black shroud
http://forums.pelicanparts.com/uploa...1331405877.jpg
Black and silver with green shroud
http://forums.pelicanparts.com/uploa...1331405901.jpg
hcoles 03-12-2012 08:39 AM
Henry,
Those engines are works of art.
I propose these could be made into a calendar, I would buy one.
-Henry
hcoles 03-12-2012 08:41 AM
I was going to mention re. sand blasting.
I've read one needs to be very careful when using sand blasting around engine parts.
Spenny_b 03-12-2012 08:57 AM
Agree with above, although some items don't present too much problem, as they don't have hidden cavities. Wouldn't go near grit blasting for things like crank case halves, cam carriers, heads, barrels, etc.
I'm about to deliver a few items for vapour blasting tomorrow (timing chain housings, A/C bracket, Carrera inlet manifold)....less harsh than sand/grit blasting and doesn't damage mating faces. I believe it also has a very mild peening effect of the surface, meaning the items don't go grimy looking if touched with greasy fingers.
hcoles 03-12-2012 09:22 AM
I like the peening affect - should keep the surface from getting blochey or as you say covered in greasy finger prints. I have no idea if this is available near me.
Spenny_b 03-12-2012 10:00 AM
Yeah its the first time I've gone this route...I dropped-off the items to be powder coated last week with one of the regions premier coaters; they had heard of vapour blasting, but didn't offer it as a service, nor knew too much about it.
A 30sec Google later, and I'd found a few companies offering it; thankfully one is only a 1.5hr drive from me, on the way to one of our offices (and they've done Porsche stuff before).
Looks to be more expensive than bead/grit blasting, but I guess you save on not needing to paint/powder coat the item afterwards
Spence.
Spenny_b 03-15-2012 10:18 AM
Here you go chaps, parts collected the same evening on the way back home from work, absolutely chuffed to bits with them.
http://img.photobucket.com/albums/v2...t/7658b3dc.jpg
http://img.photobucket.com/albums/v2...t/f339dcb7.jpg
http://img.photobucket.com/albums/v2...t/91d65f29.jpg
UK guys - if you need anything vapour blasting, then Dave @ TSR Vapour Blasting in Sevenoaks is a great bloke; he bent over backwards to help and get them done, to save me having to make a return journey....really good service, unusual these days.
hcoles 03-15-2012 02:24 PM
those fall into the over-restored category, too nice to run
Spenny_b 03-16-2012 02:30 AM
:D
Yeah, I have to say, when I offered the chain housings up to the crankcase yesterday, they did make the case halves look shoddy! Despite hours and hours (...and hours...) cleaning them.
Now waiting for the phone calls from the powder coating and plating shops to go and collect more bling...satin black (30%) covers, which I'm going to polish the Porsche text on, like one of the pics above....hopefully the satin black will look not so much retro but gun "technical".....and dozens of items in new zinc/passivate.
eastbay 03-16-2012 04:39 PM
those fall into the <s>over-restored</s> enthusiast category, and are not too nice to run
fixed it for the rest of us :D
Spenny_b 03-16-2012 06:44 PM
Originally Posted by eastbay (Post 6628240)
fixed it for the rest of us :d
Lol....good man, thanks ;)
strokher racing 03-16-2012 07:19 PM
I went with red and polished throughout....http://forums.pelicanparts.com/uploa...1331950794.jpg
dnaeseth70 03-17-2012 05:39 PM
http://www.datasea.info/avatar1.jpgThose engines are works of art.
