Looking for ideas on how to paint my engine
I have my 3.0 dropped doing a top end rebuild and headstuds. Just cleaned up and sandblasted most of the parts. Anyone have any photos I could get ideas from on how to paint the fan, shroud, etc????
Try not, Do or Do not
Black fan ring, silver fan (both powder coat) and amber shroud
![]() Gibbs fan and ring with amber shroud ![]() Gibbs fan and ring with yellow shroud ![]() Black and red ring and fan with red shroud ![]() Gibbs fan and ring with red shroud ![]() Bare metal (aluminum) fan and ring with amber shroud ![]() Powder coated silver ring and fan with black shroud ![]() Black and silver with green shroud
Henry Schmidt SUPERTEC PERFORMANCE Ph: 760-728-3062 Email: supertec1@earthlink.net |
Henry,
Those engines are works of art. I propose these could be made into a calendar, I would buy one. -Henry
Sold: 1989 3.2 coupe, 112k miles |
I was going to mention re. sand blasting.
I've read one needs to be very careful when using sand blasting around engine parts.
Kartoffelkopf
Agree with above, although some items don't present too much problem, as they don't have hidden cavities. Wouldn't go near grit blasting for things like crank case halves, cam carriers, heads, barrels, etc.
I'm about to deliver a few items for vapour blasting tomorrow (timing chain housings, A/C bracket, Carrera inlet manifold)....less harsh than sand/grit blasting and doesn't damage mating faces. I believe it also has a very mild peening effect of the surface, meaning the items don't go grimy looking if touched with greasy fingers. |
I like the peening affect - should keep the surface from getting blochey or as you say covered in greasy finger prints. I have no idea if this is available near me.
Kartoffelkopf
A 30sec Google later, and I'd found a few companies offering it; thankfully one is only a 1.5hr drive from me, on the way to one of our offices (and they've done Porsche stuff before). Looks to be more expensive than bead/grit blasting, but I guess you save on not needing to paint/powder coat the item afterwards Spence. |
Kartoffelkopf
Here you go chaps, parts collected the same evening on the way back home from work, absolutely chuffed to bits with them.
![]() ![]() ![]() UK guys - if you need anything vapour blasting, then Dave @ TSR Vapour Blasting in Sevenoaks is a great bloke; he bent over backwards to help and get them done, to save me having to make a return journey....really good service, unusual these days. Last edited by Spenny_b; 03-26-2012 at 04:47 AM.. |
those fall into the over-restored category, too nice to run
Kartoffelkopf
![]() Yeah, I have to say, when I offered the chain housings up to the crankcase yesterday, they did make the case halves look shoddy! Despite hours and hours (...and hours...) cleaning them. Now waiting for the phone calls from the powder coating and plating shops to go and collect more bling...satin black (30%) covers, which I'm going to polish the Porsche text on, like one of the pics above....hopefully the satin black will look not so much retro but gun "technical".....and dozens of items in new zinc/passivate. |
Kartoffelkopf
I went with red and polished throughout....
