GotaT's Avatar
Send a message via AIM to GotaT Send a message via Yahoo to GotaT
Oil Cooler - Leak
I have installed a New Oil cooler on my 2.4 not too many miles ago and I am beginning to see another leak. Although, i dont believe its the cooler itself, but instead I believe it to be the Seals to the engine. This appears to be the same spot in the past.
Any ideas on what to check/ any tricks to ensure the round seals are being compressed enough to the block and cooler?
Old 03-27-2012, 06:11 AM
pete3799's Avatar
Are you sure the leak isn't coming from above the cooler and leaking down?
Did you use the green O-ring seals?
Torquing the cooler mounting nuts will assure a good seal.
Pete
79 911SC RoW
Old 03-27-2012, 07:08 AM
GotaT's Avatar
It doesnt appear to be coming from above, and I did use the Green Seals. I can double check the tightness of the nuts.. but Im pretty sure they are Tight.
Im wondering if it could be that the metal(block) to metal(cooler) isnt a tight enough gap.. thus not allowing for the gaskets to compress enough?
Old 03-27-2012, 07:19 AM
I've had 3 coolers fail in the last 5 years. I haven't seen the seals ever leak. There can be a leak behind the cooler where the steel insert shows through for one of the oil galleys. Most people put JB weld on the area.
-Andy
Old 03-27-2012, 07:48 AM
GotaT's Avatar
-Andy
Now that sounds like an area for me to check. Do you have a pic of that spot to JB?
Old 03-27-2012, 07:52 AM
GotaT's Avatar
I came across this post.
Case & JB Weld question
Is that the area you are referring to JB WELD? ...
Should the cap nuts also have Black sealant applied to the threads as added precaution?
Old 03-27-2012, 09:12 AM
