Prepping Nikisil Cylinders
There has been a lot written on how to prep used Nikisil cylinders for new piston rings using hot soapy water and Scotchbrite.
I've just done this but cannot say that I can see any evidence that I have removed any cylinder glazing. I can clearly see the original hone marks. So, what should I be looking for?
I first soaked each cylinder in carb cleaner for 30 minutes. Then, using red Scotchbrite, I followed the instructions to scrub the cylinders with hot soapy water using Scotchbrite.
And, can anyone give guidance on how many minutes it should take to remove the glaze? I spent about 10 minutes per cylinder with the Scotchbrite technique.
Old 05-01-2012, 06:27 AM
Ernie,
Sounds like you've done the job,...
You WILL see the original hone marks; all you are doing is removing carbonized oil left on the surface of the bores and thats the proper procedure to accomplish this.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 05-01-2012, 08:26 AM
Thanks Steve. Looks like I am ready to go.
Old 05-01-2012, 12:41 PM
