-   -   2.0E motor into 2.0T body. (http://forums.pelicanparts.com/911-engine-rebuilding-forum/681434-2-0e-motor-into-2-0t-body.html)
LeeM 06-03-2012 02:56 AM
I've bought a 69T without a motor and have a 69E MFI engine waiting to go in, I realise it's not a straight swap, what will I need to change to make it work?
The return fuel line back to the tank is the obvious, what pump should I use?
Steve@Rennsport 06-03-2012 09:30 AM
You'll need the MFI electric pump, the return line, and the MFI fuel filter console.
LeeM 06-03-2012 12:24 PM
Thanks Steve, I already have the fuel filter.
Is there anything else?
porschemn 06-03-2012 05:33 PM
Let me know how you plan to run the return line. I'm doing the same on a 2.2 1971 T.
Matt
LeeM 06-04-2012 02:21 PM
A length of copper pipe straight down the transmission tunnel, the holes are already there.
My concern is the ignition side of things?
