safe's Avatar
Tight 2.0 engine
Hi
I got a 2.0 69 engine that is tight, almost frozen. I need a cheater bar to turn the crank. If I turn the crank 45 degrees its loose those 45 degrees, but then tightens. If I turn it around 360 degrees I can keep turning it, but it will seize again a few days later (well, I haven't timed it).
I took the engine out of a running car but I haven't driven it very long, and just one time. It has been rebuilt by someone of unknown skill. Its built of assorted parts, mag E crank case T cylinders, T cams, unknown pistons (could be E) etc.
I'm in mid teardown, it was not tight camshafts... Hopefully I get down to piston and cylinders later this week.
Could someone take a guess what the problem could be?
Magnus
Old 06-04-2012, 10:06 AM
I would rather be driving
jpnovak's Avatar
warped mag case binding the crank?
Old 06-04-2012, 11:39 AM
safe's Avatar
That is my best bet too.
But wouldn't it bind all the time or free up the whole 360 degrees once I brake it loose?
Magnus
Old 06-04-2012, 11:49 AM
304065's Avatar
"seize again a few days later"
This tells you that the mechanical clearance is changing over time
only thing that makes that happen is an organic process
known as R U S T
Rust in cast-iron cylinders.
'66 911 #304065 Irischgruen
‘96 993 Carrera 2 Polarsilber
'81 R65
Ex-'88 Carrera (Sold 3/29/02)
Old 06-04-2012, 11:57 AM
Possibly dry cylinders. With the cylinders up add some oil through plug holes and turn it over then reverse the side with plugs up.
Bruce
Old 06-04-2012, 01:51 PM
safe's Avatar
Well, I have come this far now:
With the cylinders gone I can turn the crank by the flywheel, just a little initial sticktion.
There was oil in the cylinders, I think from previous attempts from me to lubricate the pistons.
Cylinders don't look that good, but no major rust:
I have not even wiped of the C/P in the picture above, so they look a little messy.
I'm thinking that pistons to cylinder clearance might be to tight or that the piston rings are wrong.
I forgot to mention in my first post that the oil tank magnet was full of junk...
Magnus
Old 06-06-2012, 12:57 PM
safe's Avatar
Think I found the problem.
The piston skirt is too tight !
I haven't the right tools to measure the pistons, but I guess the pistons aren't supposed to get stuck??
The top of the pistons fits nicely, its just the "tabs" thats tight. that is not normal is it?
Magnus
Old 06-07-2012, 02:58 PM
not normal. in all my rebuilds etc, the pistons slide in and out without much effort (rings provide the friction). but i've never dealt with a 2.0.
Just checked my new P&C's in the shop (3.0), without rings, the pistons slide nicely in and out of the jugs.
Old 06-08-2012, 11:08 AM
