It's a trap...
Speed Buggy's Avatar
Location: 1/2 way between the Motor City and the Glass City.
I know the answer - but I thought I'd ask anyway.
Should I replace this timing chain gear? It has a funky wear pattern on it.
Run like the wind, straining the limits of machine and man....
2006 Atlas Gray Carrera 4, '81 911SC Black on Tan (SOLD), 2006 Acura RSX Type S, '13 Dodge Durango (wifeys).
Old 06-27-2012, 07:39 PM
Intermediate shaft sprocket.......
That sprocket is totally worn out. I could not imagine how the wear pattern was formed that way and looks weird. Inspect the timing chains too. No way I'm going to put that sprocket back into the engine unless the part is not available anymore.
Tony
Old 06-27-2012, 07:57 PM
It's a trap...
Yeah... ordered a new one. It feels like about 3 to 5 thousandths.
Old 06-27-2012, 08:09 PM
Targa Time's Avatar
Yeah, that sprocket is toast.
As far as the chain is concerned, ALWAYS replace the chain and sprocket together.
How does the passenger side cam sprocket look? How about the other Idler sprocket, is it worn also? That much wear on the idler sprocket would give me concern as to the alignment of the cam sprockets.
81 Targa, Bamboo Beige, 3.2 SS
Old 06-28-2012, 04:09 AM
304065's Avatar
Check your chain boxes to see if the chain has worn a groove in them-- that pattern appears to be caused by extreme misalignment of the sprockets.
'66 911 #304065 Irischgruen
‘96 993 Carrera 2 Polarsilber
'81 R65
Ex-'88 Carrera (Sold 3/29/02)
Old 06-28-2012, 05:18 AM
It's a trap...
Thanks. I will closely examine all the associated bits. I have new tensioners (reason for the rebuild), chains, and ramps.
Old 06-28-2012, 09:04 AM
