Straight shooter
Harbor Freight motorcycle lift? I'm preparing to do the exact same job on my 2.7... potentially a bit more involved if my case lost threads. The lift looks awfully handy especially for the $99 price they have them for.
Andrew 74 911 |
I used the HF ATV lift on mine. It worked well, although it's a lot easier if you take the muffler off before you remove or install the engine. The stop bar tends to get hung up on the muffler otherwise.
I don't really like the way the lift descends...has two speeds: faster and fast and they come in that order. I worked around it by quickly tapping the lowering lever - kinda slapping it...made the lift lower in brief jerks...the only way to make it descend smoothly is to slap the lowering lever all the way down quickly and then the motor falls slightly slower than a falling stone. I worked around it by lowering the car a few inches past where the engine mounting studs lined up with the transmission and then a raised the lift gently until the engine and transmission were aligned. I'd highly recommend the lift if not for the strangely designed lowering function (and the slightly misaligned safety catch on mine). But, it's really cheap (Chinese, of course) and it's constructed well enough that I didn't worry too much about it dropping my engine...and it was stable enough for me to mate my engine with the transmission while working alone. So, $69.00 well spent. |
Any updates? I sent you a PM a while back and didn't hear back from you (regarding my move) . . .
Sorry
I hit a road block on the project and felt the best way to cope with it was to go kiteboarding in Costa Rica for a few weeks. This is the first time I've checked in on here in two months. I responded to your PM today...sorry for the delay.
| Tags |
| dilivar, engine removal, head studs, headstud removal, headstuds |
