-   -   Timming high over lap cams? (http://forums.pelicanparts.com/911-engine-rebuilding-forum/685618-timming-high-over-lap-cams.html)
crashmy911 06-25-2012 06:55 PM
Anyone near Norristown Pa have any experience doing this? We have timed regular 3 liter engines and done one with a 964 cam. This seems to be a little different.
Eagledriver 06-25-2012 09:03 PM
Same procedure. Do the timing with only the number 1 and number 4 intake rockers installed, leave all the others out. (If you have already installed all the rockers, you can loosen them all the way but you still need to be careful to not drive any of the pistons into the valves.).
Once you have done the timing you can check the clearance with the various methods out there after installing the number 1 and number 4 exhaust rockers.
-Andy
