Jnikic's Avatar
3.4L Ignition timing help
Looking to see if you guys have any thoughts on baseline timing:
3.4L (3.2L with 98mm cylinders); 9.5:1; 46mm PMO carbs; stock 3.2 cam; electromotive crankfire; single plug
78 911 Coupe :: E Prepared racecar :: Stock 3.0 :: Steel widebody :: 930 brakes
78 911 Targa RSR backdate :: 3.2L :: 10.5:1 Wossner pistons / Mahle cylinders :: Twin plug crankfire ignition :: 46mm PMO
Old 07-18-2012, 08:15 AM
otto in norway's Avatar
I would think that you can use stock ignition timing for the 3.2. But Not sure how much advance you can add to it on higher revs.
Old 07-18-2012, 01:55 PM
