3.2 rebuild. I have good spark and I have good fuel injection, but no start
I have gone through the Bentley and all the individual devices on the 3.2 are in spec. I have good spark and timing with all cylinders. I have fuel injectors injecting gas. So gas and electrics are reasonably there (maybe not synchronized like they should be).
The most I can get is an occasional small backfire out the muffler. I have gone through all the docs I could find on the website and have not found symptoms like this. Anybody know of anything on the top side (like a connector or vacuum leak or plugged orifice) that I might have missed before I go back to the cams and checking all that? What is surprising me (and I am a novice) is that the vane on the intake stays closed. I would think it would open somewhat to let some air in. Helping it does nothing. Time to go study the books some more. thanks in advance for any reocmmendations Marlin |
Make sure your distributor is timed correctly to your cams. It could be trying to fire on number 4 when it should be number 1, etc. In this case the distributor needs to be rotated 180 degrees.
-Andy |
Or you could have the flywheel sensors connected backward so you have the wrong reading for the right place. Switch the 2 black connectors above #3 intake.
Bruce |
Eagledriver,
I had this on the Technical forum as well with about 19 comments, but you nailed it. I had the distributor 180 out. Engine did start, but really won't hold an idle without giving plenty of throttle. Time for more research. thanks Marlin |
| All times are GMT -8. The time now is 01:41 AM. |
