LinkBack | Thread Tools | Rate Thread |
3.2 rebuild. I have good spark and I have good fuel injection, but no start
I have gone through the Bentley and all the individual devices on the 3.2 are in spec. I have good spark and timing with all cylinders. I have fuel injectors injecting gas. So gas and electrics are reasonably there (maybe not synchronized like they should be).
The most I can get is an occasional small backfire out the muffler. I have gone through all the docs I could find on the website and have not found symptoms like this. Anybody know of anything on the top side (like a connector or vacuum leak or plugged orifice) that I might have missed before I go back to the cams and checking all that? What is surprising me (and I am a novice) is that the vane on the intake stays closed. I would think it would open somewhat to let some air in. Helping it does nothing. Time to go study the books some more. thanks in advance for any reocmmendations Marlin
Marlin Ness sadly no longer: 1967 912, 1971 911T, 1974 911 Targa, 1975 914, 1972 914 Eagle GT with V8 currently: 1972 914 Eagle GT with 3.2 Carrera, 1970 911T (964 turbo wide body look), 1986 911 Carrera |
Make sure your distributor is timed correctly to your cams. It could be trying to fire on number 4 when it should be number 1, etc. In this case the distributor needs to be rotated 180 degrees.
-Andy
72 Carrera RS replica, Spec 911 racer |
Or you could have the flywheel sensors connected backward so you have the wrong reading for the right place. Switch the 2 black connectors above #3 intake.
Bruce |
Eagledriver,
I had this on the Technical forum as well with about 19 comments, but you nailed it. I had the distributor 180 out. Engine did start, but really won't hold an idle without giving plenty of throttle. Time for more research. thanks Marlin
