Ring End Gap 2.7 Race Engine
I'm in process of building up a high compression (11:1 calculated) mechanically injected 2.7L for some club racing. Engine machine work is done and I have brand new J&E pistons (89.992mm/3.534") made for the cylinder bores (90.017mm/3.544"). Cylinder wall clearance is good @ .035mm/.001". Problem is with the new Goetze rings I got with with the rebuild kit from EBS (not their fault). When measured near the bottom of the cylinder bore (as recommended), the ring end gaps ranged as follows:
Top Ring: from .016" to .019" Mid Ring: from .013" to .018" Oil Ring: from .017" to .023" So the problem is that initial ring gap for most will be larger than recommended spec but well under the wear limit. Can I set each ring (top, middle, oil) to match the largest of the group and be ok? Thanks for your comments. Gerry |
Not sure of the question but it seems to be typical that the ring gap is bigger than what new should be. Here are a few posts of mine on a similar issue.
http://forums.pelicanparts.com/911-engine-rebuilding-forum/490923-piston-rings-wrist-pin-rod-bush.html http://forums.pelicanparts.com/911-engine-rebuilding-forum/521470-new-mahle-pistons-cylinders-2-7-a.html |
Ring End Gap
Thanks for the links. This seems to be a common occurance.
| All times are GMT -8. The time now is 02:22 PM. |
