Smart quod bastardus
1979 camshaft removal tools-NEED TO BORROW A SET
I am in need of the cam nut removal tools for the old style 1979 911/930 camshaft style. Its the big 46mm crows foot and the camshaft holding socket that I wanted to borrow or rent from one of the lucky few that own these tools.
I will need it for about a month max. I got the engine out of the car yesterday but need to hang onto the tools after I disassemble the top end while I wait for the replacement parts to come in once I find out whats damaged and then need time with the reassembly. ----- Anyone could help me out or lead me to someone that has these 2 tools and would not mind loaning them to me for a short time? Please PM me if you can help me. I really appreciate it. Fred
1979 930 Turbo....3.4L, 7.5to1 comp, SC cams, full bay intercooler, Rarlyl8 headers, Garret GTX turbo, 36mm ported intakes, Innovate Auxbox/LM-1, custom Manually Adjustable wastegate housing (0.8-1.1bar),--running 0.95 bar max ---"When you're racing it's life! Anything else either before or after, is just waiting" Last edited by fredmeister; 09-11-2012 at 08:59 AM.. |
it's a 46mm nut. you can use a 1/2" impact and 46mm socket to get them loose. tensioner out on the left side and hold the idler arm tight with channel locks between arm and the top of the chain housing as you rattle it off.
I was hesitant to use an impact on the nut as it puts a shock load into the chain that you are using to prevent the cam turning. Is this a valid concern do you think or not to worry? Thanks, Fred
1979 930 Turbo....3.4L, 7.5to1 comp, SC cams, full bay intercooler, Rarlyl8 headers, Garret GTX turbo, 36mm ported intakes, Innovate Auxbox/LM-1, custom Manually Adjustable wastegate housing (0.8-1.1bar),--running 0.95 bar max ---"When you're racing it's life! Anything else either before or after, is just waiting" |
Fred to Fred
Fred,
I have a set of the tools you need and am willing to loan them to you.......IF you promise that I will have them back in no more than 60 days. I am (dangerously) close to doing an engine build myself and will need them then. Drop me a PM with your mailing address and I will get them in the mail in the next day or so.
FEC3 1980 911SC coupe "Zeus" 3.3SS god of thunder and lightning |
Impact tools are amazing in what they can do. You won't hurt a thing using one on the big nut, and it takes all the work out of it. Well worth the cost of purchasing a 46mm socket. Still need the crow's foot for going the other way.
Tools
Think I have what U want.
But cannot ship until next Monday. -Doug
"Are you out of your Vulcan mind?" Doug 2022 Carrera 4S, 1989 Delta Integrale, 1973 911T CIS |
